03-05-2004 07:41 PM - edited 03-02-2019 02:04 PM
We are using Cisco 2610XM and NM-16A (16 Port Aysnchronous Module) and 2 sets of 8 lead ocatl cables to make a terminal server. This is going to be used for reverse telnet purpose.
The configuration file is as follows:
TerminalSrvr#show run
Building configuration...
Current configuration : 931 bytes
version 12.2
hostname TerminalSrvr
logging queue-limit 100
no logging console
enable secret xxxx
enable password xxxx
username xxx privilege 15 password xxxx
ip subnet-zero
no ip routing
ip host test1 2001 10.10.10.10
interface Loopback1
ip address 10.10.10.10 255.255.255.0
interface FastEthernet0/0
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
no cdp enable
ip http server
ip classless
line con 0
exec-timeout 0 0
line 33 40
exec-timeout 0 0
password cisco
flush-at-activation
login local
no exec
transport input all
flowcontrol hardware
line 41 48
exec-timeout 0 0
password cisco
flush-at-activation
no exec
transport input all
line aux 0
line vty 0 4
password cisco
login
end
When I try to telnet to the console port of a Cisco Switch attached asynch module, i recieve:
TerminalSrvr#telnet 10.10.10.10 2001
Trying 10.10.10.10, 2001 ...
% Connection refused by remote host
Any idea?
03-06-2004 12:00 PM
can you issue the command:
show line
and check if there might be noise on your line ?
If you see noise, according to a previous post, the noise on the console could be caused by a number of things bad cable, emi, you can try toggling the flow control between software and hardware to see if this clears up the noise issue, one additional thought , I have had instances when there is noise on a console line that the router beleives that this noise is an exec request and opens up an exec session, so perhaps this noise is creating a session on the console and this is why you can not access it on your first try, removing the cable clears the session allowing you to connect after this.
Also, you could try to configure the command "no exec" under your line configuration on your Access Server. It could prevent unwanted signals from the the line initiating exec sessions and keeping the line unavailable for genuine ones.
And last but not least, I see that you have configured lines 33 thru 48, while you are trying to connect to a host on line 1. Just make sure that your host is actually connected to port 1, otherwise change the statement:
to
ip host test1 2033 10.10.10.10
Then again I might be way off here...
Georg
03-08-2004 11:20 AM
Configure your router as detailed here:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
03-08-2004 11:59 AM
It looks like you're telneting to the wrong port. Above, you are going to port 2001. I noticed in your config that your port numbers start with 2033. Line 33 40, means ports 2033-2040. Line 41 48 means 2041-2048 So, telnet to 10.10.10.10 2033, and it should work. I hope this helps!
