Webcast-Catalyst9k
reverse telnet to device connected to nm-16a stuck at "open"
2620 router running 12.2(1) with a NM-16a board. When I reverse telnet to any tty line connected to a devices console I get stuck in the open state and cannot go any further other than breaking out of the session and disconnecting it.
Stuck Here:
sfo2600-1>prodpix-2
Trying prodpix-2 (192.168.0.1, 2039)... Open
Router Config:
Current configuration : 1712 bytes
version 12.2
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname sfo2600-1
logging buffered 4096 debugging
logging rate-limit console 10 except errors
enable secret 5 $1$Ry0N$acDNltos3eHJlEhq2.gDT.
ip subnet-zero
no ip source-route
no ip finger
ip host prodpix-2 2039 192.168.0.1
ip host prod7200-1 2035 192.168.0.1
ip host sfo6509-1 2033 192.168.0.1
ip host sfopix-1 2034 192.168.0.1
ip host prodpix-1 2038 192.168.0.1
ip host prodld-1 2040 192.168.0.1
ip host prod2980-2 2037 192.168.0.1
ip host prodld-2 2041 192.168.0.1
ip host stageuxdb01 2042 192.168.0.1
ip host stageuxapp01 2043 192.168.0.1
ip host stageuxweb01 2044 192.168.0.1
ip host produxdb01 2045 192.168.0.1
ip host produxapp01 2046 192.168.0.1
ip host produxweb02 2047 192.168.0.1
ip host produxweb01 2048 192.168.0.1
ip host prod2980-1 2036 192.168.0.1
no ip dhcp-client network-discovery
interface Loopback0
ip address 192.168.0.1 255.255.255.255
interface FastEthernet0/0
ip address x.x.x.x
no ip redirects
no ip unreachables
speed 100
full-duplex
interface Serial0/0
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no ip http server
line con 0
session-timeout 20
transport input pad v120 telnet rlogin udptn
line 33 48
session-timeout 10
no exec
exec-timeout 0 0
transport input telnet
line aux 0
line vty 0 4
password 7 021505550D140E2F
login
line vty 5 15
login
end
1 REPLY
Anonymous
N/A
Re: reverse telnet to device connected to nm-16a stuck at "open"
The default settings on line 39
are 8/N/1 9600; if the console port
of prodpix-2 is setup any differently,
you will not be able to communicate.
Once you have the reverse telnet
established (open), it's no different
than being directly connected via a
PC; this doesn't guarantee connectivity
unless the physical settings are the same.
You may also want to confirm you
have the correct cable for the device
you are connecting to.
114
