Reverse telnet to other manufacturers devices
As subject:
Can anyone suggest a good site or supplier (prefer UK or US), that understands the necessary cabling required (DB9/DB25 connector clocks really) to connect Nokia, SUN and Linux based systems to Cisco routers for remote console management.
Cheers,
Re: Reverse telnet to other manufacturers devices
Did you ever get a reply on this one?
What hardware are you using- I've got the same problem!!
Cisco 2610
NM-8A/S
What config did you use?
Many Thanks
Simon Watkins
Itex (Jersey) Ltd
First of all you need to know what kind of cable and connector need towards the devices that you want to console into.
Based on that if you want to use the cisco rotuer ro consoled into the devices, here is the cable guide from cisco which has part numbers too if you want to order.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/cis2500/2509/acsvrug/cables.htm
Now here is the url which will help you how to configure the router for console access to SUN boxes.
http://www.cisco.com/warp/public/793/access_dial/sun_comm_server.html
Also
http://www.cisco.com/warp/public/793/access_dial/comm_server.html
Hope this helps..Thx..Tejal
142
