Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
RIP and VLSM
What will happen when I try to redistribute a subnet (i.e. 10.3.0.0) from OSPF into RIP? (10.0.0.0 or subnet not exist in the RIP domain)
1 ACCEPTED SOLUTION
Silver
Re: RIP and VLSM
Since RIP v1 does not pass subnet mask information the only way that a RIP speaking router would place a mask on a learned network is based on the Mask that is configured on it's local interfaces. So, if your 10.2.0.0 was a /24 for example and the 10.0.0.0 came into this router. This router would apply a /24 bit mask to it. RIP V2 does not have this limitation..nor do most other commonly used Classless routing protocols.
Hope that helps,
Don
Silver
Re: RIP and VLSM
Since RIP is classful it would distribute the classful address from your redistributed 10.3.0.0/x as 10.0.0.0/8.
Hope this helps you,
Don
Re: RIP and VLSM
Thanks Don.
And what will the router do if a net 10.2.0.0 is configured in his RIP domain?
Silver
Re: RIP and VLSM
Hope that helps,
Don
Silver
Re: RIP and VLSM
One more thing to keep in mind ,When you redistribute Rip will apply the OSPF metric , make sure you apply a new metric when redistributing
152
