RIP on 3750 switch
do you think that this configuration will work.
atalyst3750#vlan data
Catalyst3750(config-vlan)# vlan 2 name Head Office
Catalyst3750(config-vlan)# vlan 9 name BR
Catalyst3750(config-Vlan)# vlan 204 name AppSrv
Catalyst3750(config)# int vlan 2
Catalyst3750(config)#ip address 10.170.2.1 255.255.255.0
Catalyst3750(config)#int vlan 9
Catalyst3750(config)#ip address 10.170.9.1 255.255.255.0
Catalyst3750(config)#int vlan 204
Catalyst3750(config)#ip address 204.4.4.56 255.255.255.0
Catalyst3750(config)#int gig1/0/1
Catalyst3750(config-if)#switchport mode access
Catalyst3750(config-if)#switchport access vlan 2
Catalyst3750(config)#int gig1/0/2
Catalyst3750(config-if)#switchport access vlan 204
Catalyst3750(config)#int gig1/0/20
Catalyst3750(config-if)#switchport access vlan 9
Catalyst3750(config)# ip routing
Catalyst3750(config)#router rip
Catalyst3750(config-router)#network 10.170.2.0
Catalyst3750(config-router)#network 10.170.9.0
Catalyst3750(config-router)#network 204.4.4.0
Silver
Re: RIP on 3750 switch
I am not shure why you are enabling dymic routing, since all the networks are directly connected.
Yes, RIP will run on networks 10.0.0.0 and 204.4.4.0. If you require RIP to propagate your roouting information I would suggest you switch to RIPv2.
Catalyst3750(config-router)#version 2
Leon
* Please rate posts.
yes its look okay...
just use rip verison 2 and make sure you have configured ip routing thats it
regards
Devang
Also dont forget to use "no auto-summary"
vlad
Gold
Along with the above 2 suggestion you should also only run rip on the interfaces you actually have other routers that you are going to exchange routing with.
The simple way to do this is put in
PASSIVE INTERFACE DEFAULT
No PASSIVE INTERFACE VLAN...
For example if your vlan 204 only contains servers it only wastes bandwidth to send out updates and if a misconfigured server sent you a rip route you could have major issues.
With passive interfaces it will still place the network into the rip routing table but it will not run the rip protocol on the interface.
1537
