You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
RIP Problem
When I configure RIP between a 2610 and a 2514 and then issue a "clear ip route *" I get the errors below on either router:
R2#clear ip route *
R2#
00:37:53: %SYS-3-TIMERNEG: Cannot start timer (0x72681C) with negative offset (-4000).
-Process= "RIP Router", ipl= 0, pid= 86
-Traceback= 32B1ADE 350163C 3502EC0 34FE90E 34FEEAC
R2#clear ip route *
R2#
00:38:21: %SYS-3-TIMERNEG: Cannot start timer (0x726918) with negative offset (-4000).
R2#clear ip route *
R2#
00:39:25: %SYS-3-TIMERNEG: Cannot start timer (0x72681C) with negative offset (-4000).
R2#
Any ideas or insights?
  • Other Network Infrastructure Subjects
Re: RIP Problem
Do you have CCO login? If so, have a look at the link below:
http://www.cisco.com/cgi-bin/Support/Errordecoder/error_decoder.pl?index=all&query=%25SYS-3-TIMERNEG%3A+Cannot+start+timer+%280x726918%29+with+negative+offset+%28-4000%29.+&counter=0&paging=5&links=reference&sa=Submit
I have copied your error into the Cisco 'Error Message Decoder' and the link above shows the results. Basically, an in internal software error has occured. You should contact your Cisco representative or TAC with the information of the error for further assistance.
Good luck with this.
Dazzler.
Re: RIP Problem
This is an internal software error. An IOS upgrade should help!
116
