Community Member
RIP problems
I'm trying to use RIP to sync route tables from 2 router in the same network (Cisco 2620 ios 12.2 and 12.0).
I tryied with and without authentication, but the receiver router always says:
RIP: ignored v2 packet from 192.168.0.9 (not enabled on FastEthernet0/0).
What is missing ?
ROUTER A
interface FastEthernet0/0
ip address 192.168.0.9 255.255.255.0
no ip directed-broadcast
load-interval 30
duplex auto
speed auto
router rip
version 2
redistribute static
passive-interface Serial0/0
passive-interface Serial0/1
passive-interface Serial0/2
passive-interface Serial0/3
network 200.241.84.0
network 200.242.95.0
network 200.249.144.0
network 200.249.155.0
neighbor 192.168.0.17
default-metric 10
no auto-summary
ROUTER B
ip address 200.241.84.17 255.255.255.0
speed auto
full-duplex
router rip
version 2
network 200.249.86.0
default-metric 10
Silver
Re: RIP problems
you are not advertising the 192.168.0.0 255.255.255.0 network in your Rip config
Community Member
Re: RIP problems
Thanks a lot.
It was the problem.
Bronze
Re: RIP problems
Seems like you are missing the network 192.168.0.9 on your router A and also seems like the two routers are in totally different subnet. one in 192 and other is 200.. Do you have something in the middle that connects the two router or they are connected back to back..
also did u try without the v2 and see what happened.. Other than getting the error message, are you getting the routes
Community Member
Re: RIP problems
It works !!! Thanks a lot.
I didn't want to share the routing table for the network 192.168.0.0, but when I put it, it worked.
Thanks again.
156
