Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
RJ45 module "fixed" after conversion to Native mode!!!
This is a strange one. We have a 6509 switch with the following modules:
1 Cat 6k sup 1 Enhanced QoS (Active)
2 Cat 6k sup 1 Enhanced QoS (Standby)
3 8 port 1000mb GBIC Enhanced QoS
4 8 port 1000mb GBIC Enhanced QoS
5 48 port 10/100 mb RJ45
6 48 port 10/100 mb RJ45
8 48 port 10/100 mb RJ45
...with the following sub-modules:
1 Policy Feature Card
1 MSFC Cat6k daughterboard
2 Policy Feature Card
2 MSFC Cat6k daughterboard
8 Inline Power Module
We recently decided to remove the 6509 from service and upgrade to Native mode IOS. When we took down the switch and booted it up in our test lab we found that module 6 (RJ45) was faulty - it failed on all ports doing the loopback tests.
Ignoring the above, we proceeded to convert to native mode IOS (c6sup11-dsv-mz.121-13.E4). Now that we have successfully done this, we find that the module is now showing as OK and functional!!! Can anyone suggest what might be going on here?
During the upgrade of the primary supervisor (1) we pulled out the secondary (2) to avoid problems and ensure a backout; when the upgrade of 1 had finished we noticed that module 6 was OK. We then removed module 1 and inserted module 2 and found that module 6 was in the same old failed state!!!
I can only guess that the new IOS is not performing the same stringent tests that the old CatOS was doing and it is passing the module when in fact there could be a problem.
Any advice would be appreciated.
Thanks...
Re: RJ45 module "fixed" after conversion to Native mode!!!
Hi Kadri
The following are the possible errors that can be associated with the LED status.In the future of failures in the modules to diagonise the cause please be sure to issue the command show test from the console prompt od the switch.
The following URl can give you more picture on the status and the nature of the problem in relation to the LED status.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015504b.shtml#topic3
Vatsan
Hi Vatsan,
Thanks for your response. The show test command is no longer available in Native mode! The link to the document you gave me was for Hybrid mode troubleshooting only. I have done the usual reseating of the module, etc, etc.
The more I delve into the caveats for Native mode the more I feel that I should back out to Hybrid. It seems that a few functions are not available to me as I have a sup1 (sup2 is ok).
Can anyone else help?
Much appreciated...
Tariq.
132
