RME 24-hour reports not opening.
gopeshm
I have RME 3.3 on LMS2.0 on Windows2K and I am taking RME 24-hour reports. I get a "downloading data" and eventually a timeout. I am unable to open any of the reports like "syslog report", "change audit report" etc.. under the 24-hour report. Can anyone suggest a workaround f this.
Gopesh
amritpatek
Level 6
Level 6
This can happen if the RME database it too large. There are 2 related bugs in this connection, CSCdv02897 and CSCdm53348. If the registered devices are 1400 or more..then it is unable to download such a huge data.Or it might be caused due to the browser too. Which browser are you using? Try changing to another browser. Following troubleshooting tips might be helpful.
Troubleshooting Essentials
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_3/u_guide/ug_appa.htm
