RME 3.2 Not able to telnet to device
Have CW2K running on W2K with RME 3.2. When trying to do an image upgrade to Cat 3500XL and 2900XL switches I get errors cant telnet to device.
I then atttempt code upgrade to same device again and it will work. Sometimes it takes 4 or 5 attempts or more and happens on all switches. I know telnet passwords are correct because I can telnet to all switches from a DOS prompt using same password at ant time. TAC has been working on this with no success. Thanks
Re: RME 3.2 Not able to telnet to device
Have you tried manually setting the telnet password and other attributes in RME for each device?
Blue
DId you do a Check Device Attributes in RME to see if they return the correct results?. Also, try getting a sniffer trace which will exactly tell why and where RME is failing.
99
