RME 3.3 and Catalyst 2950G-48-EI
thomas.giesecke
I tried to manage a 2950G-48-EI with RME 3.3 but the device is only recognized as native snmp device.
As I looked through the supported SNMP OID's for RME I only found the OID for three 2950 Switches ending with .323 .324 .325
But the OID of 2950G-48-EI ends with .429.
Is there any way to enhance RME 3.3 to support this switch?
Thanks in advance
Thomas
rmushtaq
Level 8
Level 8
.429 is not currently supported by RME 3.3. You can verify this by going to RME Server Configuration->About the Server->Applications and Versions->Applications Installed->Inventory Manager. There is no sysObjectID listed for this device. Currently, there's no way to manually add the support for this device in RME 3.3
Do you know about a time frame when it will be supported ?
Will this be a patch or a new release?
Thomas
Most likely in the next release of RME.
