06-30-2003 07:50 AM - edited 03-02-2019 08:31 AM
We discover a very mysterious problem:
RME does not synchronize its manually added devices to ANI (only the devices that ANI discovered itself) but ANI synchronizes its devices to RME...
The log looks like that:
2003/06/30 17:30:35 VBJ ThreadPool Worker ani ERROR OrbSdivService: Transferring IN HTTP MODE OR HTTPS WITHIN SAME SERVER
2003/06/30 17:30:35 VBJ ThreadPool Worker ani ERROR OrbSdivService: sending url http://x.x.x.x:1741/CSCOnm/servlet/com.cisco.nm.cmf.servlet.CsAuthServlet?cmd=authUser&name=admin&pwd=YWRtaW4=
2003/06/30 17:30:35 VBJ ThreadPool Worker ani ERROR OrbSdivService: Got DataInput Stream
2003/06/30 17:30:35 VBJ ThreadPool Worker ani ERROR SyncUpManager: Transferring IN HTTP MODE OR HTTPS WITHIN SAME SERVER
2003/06/30 17:30:35 VBJ ThreadPool Worker ani MESSAGE AniMain: Properties will be read from C:\PROGRA~1\CSCOpx\etc\cwsi\ANIServer.properties
2003/06/30 17:30:40 ImportFromRME ani ERROR SyncUpManager: Transferring IN HTTP MODE OR HTTPS WITHIN SAME SERVER
2003/06/30 17:30:41 ImportFromRME ani MESSAGE DBConnection: Created new Database connection [hashCode = -476235632]
2003/06/30 17:31:44 DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection [hashCode = -476235632]
Does anyone have a suggestion for that because we need to see all the devices in Campus Manager!
Thank you so much!
Uli
06-30-2003 10:31 AM
Have you applied the latest IDUs for both RME and Campus from CCO?
07-01-2003 01:34 AM
I do not know exactly if the latest IDUs are installed but normally the installed IDUs have the same release for RME and Campus. Then it should work anyway, shouldn't it?!
I will install the latest releases and come back to this conversation, thank you!
07-01-2003 05:25 PM
Not necessarily. IDUs not only contain new device support but fixes to several bugs. So, it's good to always update these to the latest from CCO. You can goto Server Configuration->About the Server->Applications and Versions to see what/if any IDUs are installed and update them accordingly from CCO.
07-07-2003 11:11 AM
It's the normal behavior, for RME to send only the devices that has been discovered by ANI.
Patrick Vignaud.
07-09-2003 04:47 AM
Yes, it seems to be this way, because I let ANI "discover" some Routers by enter them as seed device and then they were synchronized to RME and back. But if I understood the manual correctly then this is not a feature but a bug. You can read there that manually entered device in RME would be synchronized to ANI!!!
So, how can this be achieved???
Btw, there exists no IDU 4.0 for CM3.2 therefore we have to upgrade to CM3.3 but I still don't believe that this is the main problem.
Greez
