Webcast-Catalyst9k
Rookie needs help with router issues
I have two Cisco 2501's connected via point to point DS1. One either end the server connected to a hub can ping both the Ethernet and Serial interfaces on the local router. When I telnet in to the router on this end, I can ping the other router. However, I can't ping from either server to the remote router. Any help would be greatly appreciated.
Here are the interfaces on each router
Router 1
hostname Hiram
enable secret 5 $1$98xK$eDEU9fnE36HI2VewylEcW/
interface Ethernet0
ip address 15.100.100.1 255.255.255.0
interface Serial0
ip address 172.17.1.1 255.255.255.252
interface Serial1
no ip address
shutdown
no ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
________________________________
Router 2
hostname Fidel
enable secret 5 $1$PJc4$YiCu7bqx/8YMWxE65Yh1o.
interface Ethernet0
ip address 15.100.200.1 255.255.255.0
interface Serial0
ip address 172.17.1.2 255.255.255.252
interface Serial1
no ip address
shutdown
no ip classless
1 ACCEPTED SOLUTION
Re: Rookie needs help with router issues
Add a default route on Router 2 so that packets can get back.
I know that I need to add:
no ip classless
and pls excuse my ignorance as my router tech is out today, but how do I add that that to the interface, I am telnet'ed in, just need command to do so
Bronze
assuming these routers do not need to talk to any other routers then you just need to add another static default route in fidel pointing back to hiram
ip route 0.0.0.0 0.0.0.0 s0
then on both routers add
ip classless
82
