Hope you could help,
> I have a network consists of 4 sites with IP CLEAR connected to 2610xm,and 7 sites have ISDN link back to core sites.
> at each core sites ,2 fastethernet ports are used to connected to 3550 emi(12.14) ,at each sites both swithes have approx 6 vlans are created and HSRP is in use. + both 3550`s are conneted to fa0/1-2 PORTS to form a trunk.
> also between 2 sites LES 100 ,is provided for full Redundancy ,in case if IP Clear fails so LES CAN BE used ,and provide a alternative path from remote site.
**>>> my problem is core routers are runnung bgp,and there are 4 AS ,and all 3550 emi `s are running ospf fro local vlans.and connection between router and 3550 is Routed interface.
***>> is there any way to run a protocol,instead of providing static routes to remote sites from 3550.
now I am running bgp in ip clear and ospf-locally.
>>unable to make a forced entry in case static route to the ip clear router fails ,is there any way I could forced them to use LES and use the remote site.
>>> this solution is fully Redundant ,I hope .
Thanks.
Sam
