Webcast-Catalyst9k
Route between VLAN's using a 3750
Hello, I would like to use my 3750 switch as a level 3 switch so I can route between vlans.
Please reference the config below.
I currently have 5 vlans set up. Just for test purposes I have a PC in VLAN 2 and a PC in VLAN 6.
Vlan 2 IP address is 192.168.1.1 255.255.255.0
Vlan 5 IP address is 192.168.5.1 255.255.255.0
The PC on VLAN 2 has the ip address of 192.168.1.2 255.255.255.0 default gateway 192.168.1.1
The PC on VLAN 6 has the ip address of 192.168.5.2 255.255.255.0 default gateway 192.168.5.1
I have enabled ip routing in the config.
Niether PC can ping the other, with the PC in Vlan 2 giving this message ?Reply from 192.168.1.1: destination host unreachable
And the PC in Vlan 6 giving this message : Request timed out
Can anyone tell me where im going wrong?
Many thanks.
Test#show run
Building configuration...
Current configuration : 3766 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Test
enable secret xxxx
enable password xxx
no aaa new-model
switch 1 provision ws-c3750-48p
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
switchport access vlan 2
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
switchport access vlan 3
interface FastEthernet1/0/36
switchport access vlan 4
interface FastEthernet1/0/37
switchport access vlan 5
interface FastEthernet1/0/38
interface FastEthernet1/0/39
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
interface FastEthernet1/0/43
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
no ip address
shutdown
interface Vlan2
interface Vlan3
ip address 192.168.2.1 255.255.255.0
interface Vlan4
ip address 192.168.3.1 255.255.255.0
interface Vlan5
ip address 192.168.4.1 255.255.255.0
interface Vlan6
ip address 192.168.5.1 255.255.255.0
ip classless
ip http server
control-plane
line con 0
exec-timeout 0 0
line vty 0 4
password test
no login
line vty 5 15
password test
no login
end
Purple
Re: Route between VLAN's using a 3750
Have you actually created the VLANs using the VLAN database ?
If not, enter VLAN configuration mode using the command 'vlan database' and then create both of these VLANs.
Hope that helps...
Paresh.
PS. Pls do remember to rate posts.
No i havent, how do i enter vlan config mode?
Many thanks
Purple
Simply enter in the command 'vlan database' from the privileged exec mode i.e. from the switch# prompt. You do not need to enter configuration mode.
Then enter in the following commands:
vlan 2
vlan 5
Both the VLANs will then be created with default paramaters...
Hope that helps - pls do rate the post if it does.
Paresh
This does not seem to help, i saved the config and rebooted the switch and PC's and i still get the same results.
Any ideas?
Purple
Can you post the output of:
- show vlan
- show interface vlan2
- show interface vlan5
Paresh
Test>show vlan
VLAN Name Status Ports
1 default active Gi1/0/1, Gi1/0/2, Gi1/0/3
Gi1/0/4
2 VLAN0002 active Fa1/0/1, Fa1/0/2, Fa1/0/3
Fa1/0/4, Fa1/0/5, Fa1/0/6
Fa1/0/7, Fa1/0/8, Fa1/0/9
Fa1/0/10, Fa1/0/11, Fa1/0/12
3 VLAN0003 active Fa1/0/13, Fa1/0/14, Fa1/0/15
Fa1/0/16, Fa1/0/17, Fa1/0/18
Fa1/0/19, Fa1/0/20, Fa1/0/21
Fa1/0/22, Fa1/0/23, Fa1/0/24
4 VLAN0004 active Fa1/0/25, Fa1/0/26, Fa1/0/27
Fa1/0/28, Fa1/0/29, Fa1/0/30
Fa1/0/31, Fa1/0/32, Fa1/0/33
Fa1/0/34, Fa1/0/35, Fa1/0/36
5 VLAN0005 active Fa1/0/37, Fa1/0/38, Fa1/0/39
Fa1/0/40, Fa1/0/41, Fa1/0/42
Fa1/0/43, Fa1/0/44, Fa1/0/45
Fa1/0/46, Fa1/0/47, Fa1/0/48
6 VLAN0006 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
5 enet 100005 1500 - - - - - 0 0
6 enet 100006 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
Test>show interface vlan 2
Vlan2 is up, line protocol is up
Hardware is EtherSVI, address is 0017.9580.1b41 (bia 0017.9580.1b41)
Internet address is 192.168.1.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1020 packets input, 77853 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
1013 packets output, 74342 bytes, 0 underruns
0 output errors, 0 interface resets
hi micheal,
with your posting, i havn't seen any of the ports having "switchport access vlan 6", since your trying to ping from vlan 2(192.168.1.2) to vlan 6(192.168.5.2) pc, you need set "switchport access vlan 6" on the port where 192.168.5.2 pc is connected.this could the reason for not pinging.
hope this helps.
rate this post.
Purple
Michael,
Can you try and configure 'switchport mode access' under the interfaces that are connected to the PCs that you are testing from ?
Paresh
I have added switchport mode access on ports 1 and 47.
What does this command do? Im trying to understand in order to configure properly.
thanks.
Mike.
Purple
By default, switches will try and form a trunk over the link if possible. This command hard-cores the interface to function solely as an access port.
Paresh
Ok thanks for that, i still get the same results. No luck.
IS the config correct in principle?
I am working from this link, but obvisouly my set up is simple comapared to the cisco site.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
How is it supposed to work if there is neither static routes configured or dynamic route process started?
Throw me of the forum if you will, but does that mean my config is correct or i have gone wrong some where?
a little late in this post sounds intresting . Michael can you do couple of steps please and post the results .
1. can you ping the default gateway .
2 can you do a shut no shut on that vlan interface please
thank
nh
hi micheal,
hope this helps.
rate this post.
Indeed you are correct, user error, i have managed to magic vlan 6 up from no where. I have just changed the PC which i thought was on vlan 6 to have a vlan 5 IP address and everything is pinging fine.
Many thanks for your help I will rate all your posts with a 5.
Thanks again!!
Ok, the PC on vlan 2 I can succefully ping the gateway.
The PC on VLAN 6 I can not = Request timed out.
I have performed a shutdown then a no shutdown for both VLANS (2 and 6) from the "test(config-vlan)#" prompt. No change.
hi micheal,
post the rate which is there in the right side of the screen with the ratingz.
259
