route-map and acl between 2 ISPs
I have a 2620 connected to 2 ISPs - I have 10 local hosts with private IPs that need to be static NAT and pointed to 1 of the ISPs and the rest of the local hosts will be NAT to a pool to the other ISP. This what I have so far - my problem is with the access-lists -
How do I have the access-lists know that I only want 10.17.0.3 - 30 allowed access to ISP2 and the rest allowed access to ISP1? Do I need a second route-map and access-list or will the default route take care of that? Any other suggestions would be appreciated.
int fa0/0
ip address 10.17.0.2
ip policy route-map ISP2
ip nat inside
int s0/0
connected to ISP1
ip address x.x.x.x
ip nat outside
int s0/1
connected to ISP2
ip address y.y.y.y
ip nat outside
ip route 0.0.0.0 0.0.0.0 x.x.x.a
access-list 199 permit ip ????????
route-map ISP2 permit 10
match ip address 199
set ip default next -hop y.y.y.b
1 REPLY
Bronze
Re: route-map and acl between 2 ISPs
Your post is very interesting for me.
I was thinking if this document would help:
http://www.cisco.com/warp/customer/105/nat_routemap.html
Do you use different range of public IPs from the two ISPs?
If so, do ISP-1 allow you to send them packets using ISP-2's address
as your source address? and vice-versa?
I have asked this because I was trying to write
the configs but I do not want to make some assumptions.
Hope this helps.
82
