Route Problem
I have a customer with 2 cisco 2600's that connect over a t1. The customer has addtrans that manage the t1 and our connected via serial v.35 ports on the 2600's. They are trying to route between to lans. The problem is that the routers see each other fine. Ping and traceroute is great between serials and ethernet ports on both the routers. Router A host's can ping across the connection to hosts on the Router B lan and get replies. Router B cannot ping back across the connection to host attached on the Router A lan side but can ping Router A's ethernet address. Below are the configs for router A and Router B.
Thank you for any help you can provide.
Router A Config
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname RouterA
enable secret *****
ip subnet-zero
ip routing
interface Ethernet 0/0
no shutdown
description connected to EthernetLAN
ip address 192.168.0.13 255.255.255.0
keepalive 10
interface Serial 0/0
no shutdown
description connected to RouterB
ip address 10.10.10.2 255.0.0.0
encapsulation hdlc
ip classless
! IP Static Routes
ip route 172.168.1.0 255.255.255.0 10.10.10.1 1
Router B Config
hostname RouterB
enable secret ****
ip subnet-zero
ip routing
no shutdown
description connected to EthernetLAN_1
ip address 172.168.1.1 255.255.255.0
keepalive 10
no shutdown
description connected to RouterA
ip address 10.10.10.1 255.0.0.0
encapsulation hdlc
ip classless
! IP Static Routes
ip route 192.168.0.0 255.255.255.0 10.10.10.2 1
Re: Route Problem
Make sure the hosts you are trying to ping have a default route pointing to router A LAN interface ip address.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Re: Route Problem
The host default route is set to Router A ethernet ip address. The host can even telnet into router B, but router B cannot even ping the host.
Re: Route Problem
assuming you are using the same src and dst ip addr and unless you have some sort of ACL in the path that allows telnet but not pings, if you have connectivity in one direction you will have it also in the reverse direction.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: Route Problem
Well I dont see anything in the running-config that would deny pings. I would agree with you that is the routes are there and can be traveled from Router B Serial to Router A ethernet then that same route should work from Router B serial to Host on Router A ethernet lan given the host has a default route for Router A ethernet. I also thought it could be an acl but I don't see anything in the config what you see is what is running on the routers.
By the way, Thank you for the feedback.
109
