Route problem
I have a Router A and a Router B directly connected. On both Routers eigrp (distance 170) and Rip(AD 120) are running. On Router B the ip address of eo is 10.10.1.2/24 and a computer is connectes with ip 10.10.1.11/24. From Router A i can ping the 10.10.1.2/24 but not the 10.10.1.11/24 which is the PC. The strange thing even from Router B i can not ping the 10.10.1.11/24.
All routes are advertise by poth protocols as
router rip
network 10.0.0.0
router eigrp 1
distance 170 0.0.0.0 255.255.255.255
network 0.0.0.0
What might be the problem?
moses
Hall of Fame Super Blue
Re: Route problem
Check
1) Do you have a personal firewall on your PC.
Also just for completeness make sure you have default-gateway on PC set to 10.10.1.2 and the correct subnet mask of 255.255.255.0.
Jon
Re: Route problem
Yes jon i checked everything those. They are ok.
Re: Route problem
post the configurations for both routers
145
