routed and routing protocol
can anyone easily describe with example of basic difference routed and routing protocol .
Biplob
Purple
Re: routed and routing protocol
A routed protocol is one that has addressing that can be used to transmit its packets from one network segment to another via an interconnected system of layer 3 routing devices. Examples of this include IP, IPX, CLNS. These protocols use addresses that indicate where each host carrying that address is located. On the basis of that, packets can be forwarded to the correct location.
A routing protocol, on the other hand, is a protocol that disseminates information about where each network is located so that it can be subsequently used by routing devices to forward packets. Examples include OSPF, RIP, IS-IS.
Hope that helps - pls rate the post if it does.
Paresh
Silver
Routed protocols are protocols that are routed over an internetwork. Examples of such protocols are the Internet Protocol (IP), DECnet, AppleTalk, Novell NetWare, OSI, Banyan VINES, and Xerox Network System (XNS).
Routing protocols, on the other hand, are protocols that implement routing algorithms. Put simply, routing protocols are used by intermediate systems to build tables used in determining path selection of routed protocols. Examples of these protocols include Interior Gateway Routing Protocol (IGRP), Enhanced Interior Gateway Routing Protocol (Enhanced IGRP), Open Shortest Path First (OSPF), Exterior Gateway Protocol (EGP), Border Gateway Protocol (BGP), Intermediate System-to-Intermediate System (IS-IS), and Routing Information Protocol (RIP). Routed and routing protocols are discussed in detail later in this book.
Rate if it does
Rgs,
HI
Thanks for clear the issue.
Biplob
442
