08-27-2006 12:57 AM - edited 03-03-2019 04:42 AM
What is the difference between Routed Protocol & Routing Protocol
TX
08-27-2006 01:06 AM
Routed protocols are protocols that are routed over an internetwork.
Routing protocols are protocols that implement routing algorithms.
routed protocol = IP,Appletalk ..
routing protcolol = rip, ospf, eigrp..
08-27-2006 01:56 AM
Its a common misunderstanding which many including me have faced.
Routed is the protocol that is routed or we can say the protocols that move around Eg: Ip,IPX/SPX
and routing protocols are the ones that are significant to the equipment and that take care of information and make communication possible Eg..EIGRP, OSPF
Ive taken the liberty to write elaborately hope it helps...
08-27-2006 02:25 AM
10xs for all ur reply
