Router 2621 Route between LAN segments
I have a new cisco 2600 router. It is used to segment beetween 2 internal lan nets - 10.10.0.0 & 10.80.0.0.
I have the interfaces set with correcct IP. THey are both up.
From the router I can ping all stations on either network fine.
I can not ping from a workstation on the 10.10. network to the 10.80 network. It is not crossing the router. IP and IPX routing is set on both interfaces.
I thought that the routing was automatic.
What could the problem be?????
Thank you
Re: Router 2621 Route between LAN segments
Hi.
Do you have the defaut gateway set on the workstations?
Hope it helps.
NM
Thank you. Yes I have a PC on the 10.80 network with a default gateway of the 10.80.1.1 interface on the router.
When I try to ping the 10.10.1.1 int on the router from the pc on the 10.80. segment I get the following message "request timed out" , when I try to ping another PC on the 10.10.0.0 network (beyond the router) I get the following message "destinaation host unreachable"
I do not have default gateways set on the router itself. I read not to do this if IP routing is enabled. How can I verify that it is??? I did the IP routing command in priv exec.mode.
ANy other suggestions.
Thank you
Hi.
I assume you are using a /16 mask. Am I right?
Do you have ACLs?
Can you post the router configuration?
If not, please post at least the output from "show ip route" and the interfaces configuration.
Try to do an extended ping from the router to a host on network 10.10.0.0 using as source IP 10.80.1.1. Do the same to a host on net 10.80.0.0 but with a using source IP 10.10.1.1.
Rgds.
NM
It still is not working . below is my config. I removed the passwords.
There are no access lists present.
On the bottom of the config I pasted the results of an SHOW IP ROUTE command.
I ultimately want to have IPX and IP route between the segments.
CONFIG:
version 12.1
service config
service timestamps debug uptime
service timestamps log uptime
hostname 2600
enable secret
enable password
ip subnet-zero
ipx routing 0008.a3d0.52e0
interface FastEthernet0/0
ip address 10.80.1.1 255.255.0.0
no ip mroute-cache
speed auto
half-duplex
no cdp enable
no mop enabled
interface FastEthernet0/1
ip address 10.10.1.2 255.255.0.0
duplex auto
speed auto
no cdp enable
ip classless
no ip http server
snmp-server engineID local 0000000902000008A3D052E0
snmp-server community public RO
banner motd _2621 - Unauthorized access is prohibited_
line con 0
exec-timeout 0 0
transport input none
line aux 0
line vty 0 4
password
login
no scheduler allocate
end
Here is what I get when I type SHOW IP ROUTE
Cisco2600#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/16 is subnetted, 1 subnets
C 10.80.0.0 is directly connected, FastEthernet0/0
Purple
I don't see it or missed it where you have any routing protocol configured ? What are you running, ospf, rip ,eigrp etc.... this needs to be configured on the router in order to rout packets . Assign a routing protocol then do your network statements .
Thank you. I can now ping on both sides. For IPX do I need to assign an IPX segment number to each interface for it to route properly?
Thank you
Hi.
You dont't need to enable any routing protocol in order to route IP packets between two directly connected networks... Can you post the output from the following commands : "show interface" and/or "show ip interface brief"? I think the interface connected to the 10.10.0.0 network shouldn't be up because network 10.10.0.0 isn't on the routing table!
Are you sure that the gateway set on the hosts on network 10.10.0.0 is 10.10.1.2?
Regarding the IPX question, the answer is yes.
Rgds.
NM
219
