router 4500 ios recovery help
I erased router 4500 ios and then the router in the rommon mode. all available commands:
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cookie display contents of cookie PROM in hex
dev list the device table
dir list files in file system
dis disassemble instruction stream
dnld serial download a program module
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
unalias unset an alias
unset unset a monitor variable
rommon 10 > so right now i can not use copy tftp flash even i can not use xmodem.because no commands for those function
what can i do now?
thanks in advance !
1 REPLY
Re: router 4500 ios recovery help
What Sup engine is it. Does it have a CF slot on it. You could load the image into CF and then boot off of it. (This will work only in Sup II-Plus, III,IV or V)
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_example09186a0080094ecf.shtml
102
