Webcast-Catalyst9k
Highlighted
router 770 problems
Have cisco router 770 in school, lan with 35 PC's connecting through router to Internet. Can only get 20 pc's onto internet,all 35 can access every thing on the lan but only 20 can access the internet. Does the router store the mac addresses in it's memory and only allow a set number of addresses?
1 REPLY
Re: router 770 problems
I don't think thats the case. Cisco 770 Router is only used for a small Lan design and if I am not wrong cisco says that it should handle only 8 Pc's(you can crosscheck in the Cisco 770 manual) but still you are able to use 20 Pc's.
I would suggest you to go for one more 770 router and with one more ISDN line as it will improve the performance of the Lan and all the users will not find the speed of the internet slow while browsing it. Also you will can accomodate 5 users for the future growth as total are 35 and you can go for 40 users on 2 seperate routers.
As per my own experience on Cisco 775 Routers thats my advice and I hope it will help you.
Sameer
119
