06-17-2006 01:45 AM - edited 03-03-2019 03:41 AM
from my router I can ping internet, from PIX and from my ethernet I can't
I have a pool of public IP,one of this is on the interface Vlan1 of router, another is on the outside of PIX
from PIX I can ping the Vlan1 of router but not internet
ROUTER
interface ATM0
description adsl (Net Ride Adsl)
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode aut
interface ATM0.1 point-to-point
ip address 151.5.134.38 255.255.255.255
no ip route-cache
no ip mroute-cache
pvc 8/35
oam-pvc manage
oam retry 3 3 3
encapsulation aal5snap
interface Vlan1
ip address xxx.xxx.xxx.66 255.255.255.240
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.1
PIX
ip address outside xxx.xxx.xxx.67 255.255.255.240
ip address inside 172.20.0.19 255.255.0.0
global (outside) 1 xxx.xxx.xxx.68-xxx.xxx.xxx.78
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.66 1
can you help me? thanks
Solved! Go to Solution.
06-20-2006 04:15 AM
You will have to check with your provider as I strongly suspect that they do not have a route pointing back to your public pool.
06-17-2006 03:31 AM
Try doing an extended ping from your router with int vlan 1 as the source address. If that is not successful then we know where the problem is but if that is successful we can move in other troubleshooting directions.
By the way in your PIX config it will be wiser to have one entry for PAT in case your pool becomes exhausted. You can do that in the following manner:
global (outside) 1 xxx.xxx.xxx.68-xxx.xxx.xxx.77
global (outside) 1 xxx.xxx.xxx.78
06-19-2006 11:44 PM
I tried the extended ping with Vlan1 as source address and the result is not successful
06-20-2006 04:15 AM
06-23-2006 12:15 AM
I have contacted the provider and the problem was just that one, now I can reach internet from Vlan1
thank you very much
