Router DHCP Straight Through / Cross Over
Hi All
   I am encountering a very strange issue. I've configured our 1921 router with DHCP. Then I've connected my laptop (to test) using a straight through and cross over to the router, but it doesn't pull an IP. I followed the commands and verified it from several sites. What else could be wrong?
ip dhcp pool DHCPPOOL
network 192.168.1.0 255.255.255.0
dns-server 4.2.2.2
default-router 192.168.1.1
ip dhcp excluded-addrss 192.168.1.1 192.168.1.99
service dhcp
Appreciate any input!
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Purple
you did a typo in your second ip dhcp excluded-address command by typing a 68 in second octet instead of 168
and by doing so you excluded all the addresses from your /24 scope.
don't forget to rate if helpful.
Regards.
Alain
Purple
Could you post the running config.
Regards.
Alain
Current configuration : 3860 bytes
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.68.1.150 192.168.1.254
ip dhcp pool DHCP-POOL
dns-server 66.80.131.5 66.80.130.23 64.7.11.2
lease 7
no ip domain lookup
ip cef
crypto pki trustpoint TP-self-signed-1406017923
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1406017923
revocation-check none
rsakeypair TP-self-signed-1406017923
crypto pki certificate chain TP-self-signed-1406017923
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 0505003
        quit
license udi pid CISCO1921/K9 sn XXXXXXXXXXXXX
username grant privilege 15 secret 5 $1$LgZ4$UXZanBF9.F45dXzBT1Fqy.
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0/0
ip address x.x.x.82 255.255.255.240
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip nat inside source static tcp 192.168.1.18 3389 x.x.x.84 3389 extendable
ip nat inside source static tcp 192.168.1.21 3389 x.x.x.85 3389 extendable
ip nat inside source static tcp 192.168.1.24 3389 x.x.x.86 3389 extendable
ip nat inside source static tcp 192.168.1.45 3389 x.x.x.87 3389 extendable
ip route 0.0.0.0 0.0.0.0 x.x.x.81
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
Router#
Bronze
When you connect the active and powered on host to the router, does the router interface become active (Up/Up)?
Is the host setup to request a DHCP address?
Frank
Yes the interface becomes up and up and yes my laptop is set to recieve DHCP.
Strange huh?!
Purple
Regards.
Alain
Oh man how embarrassing.
Thanks.
523
