Webcast-Catalyst9k
router, interface fast ethernet down when...
my router communicates with a 2924XL switch, i configured ntp and syslog and since that the fast ethernet link down periodically. The router has an e1 channelized, i configured it as a ntp master clock. Now i am troubleshooting and i want to know if ntp or syslog configuration can do that with my router???
1 REPLY
Bronze
Re: router, interface fast ethernet down when...
Sounds like you are on the right track. If your Ethernet interface is bouncing up and down, definitely get to the root of that problem though. Do a “show interface” and check to ensure you are not seeing some sort of anomalies.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1904.htm
113
