Router Interfaces keep going down
Hello there,
I have router 7204, almost every day at no specific time, all router interfaces go down for a few seconds and then they come back up again. here is the content of the router log. Can someone point me to what might be going on.
Thanks.
00:00:11: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
00:00:11: %LINK-3-UPDOWN: Interface Serial1/0, changed state to down
00:00:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
00:00:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
00:00:12: %CONTROLLER-5-UPDOWN: Controller T1 2/0, changed state to up
00:00:12: %SYS-5-CONFIG_I: Configured from memory by console
00:00:12: %SYS-5-RESTART: System restarted --
IOS (tm) 7200 Software (C7200-JS-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 07-Dec-99 16:53 by phanguye
00:00:13: %LINK-3-UPDOWN: Interface Serial2/0:0, changed state to up
00:00:13: %LINK-3-UPDOWN: Interface Serial2/1:0, changed state to down
00:00:14: %LINK-3-UPDOWN: Interface Serial1/0, changed state to up
00:00:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0:0, changed state to up
00:00:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1:0, changed state to down
00:00:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
00:00:24: %CONTROLLER-5-UPDOWN: Controller T1 2/1, changed state to up
00:00:26: %LINK-3-UPDOWN: Interface Serial2/1:0, changed state to up
00:00:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1:0, changed state to up
Gold
Re: Router Interfaces keep going down
Hi Sam --
Q. Is this a Frame-Relay Network?
Q. Have you spoken to your service prvider and if so, what have they said?
Thanks -
No, this is a point to point T1/T3 lines.
The service provider tells us that there is no line errors. It shows that in the sh interface serial command that there is no transitional errors.
Thanks.
Silver
your router is either crashing or it is losing power , look at a sh ver this will tell you if it is power or a crash , if it is the same time each day chances are the router is plugged in to something that is on a timer .
The uptime on the router is 2 hours, I think you're right as to why the router keeps crashing everyonce in a while. Could it be the power supply on the router or could it be a UPS issue.
Thanks for your help.
Silver
A 7200 would be complaining about a bad power supply , My guess is that the power strip is on some kind of timer that resets at the same time each night , the router is resetting at the same time each night .
No, the router resets at different times, sometimes once a day, once every two days or once every weeks. I wonder if there is an existing issue the current verion of the IOS.
IOS (tm) 7200 Software (C7200-JS-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2) .
I want to check the cisco website and find out if there is a known issuses. I'll probably need to upgrade the IOS before taking any further actions.
Thanks.
Silver
We have run 12.0(7) T on many routers and this code is not very stable.
If you are hitting a bug it will tell you in a sh ver , it will sh last restart via software forced crash or something like that ,
paste in a sh ver
Here is the output of sh ver.
Image text-base: 0x60008900, data-base: 0x618CC000
ROM: System Bootstrap, Version 12.2(1r) [dchih 1r], RELEASE SOFTWARE (
LP-RTR uptime is 8 hours, 36 minutes
System returned to ROM by bus error at PC 0x604BFBBC, address 0xC at 1
C Wed Jul 2 2003
System restarted at 11:16:59 UTC Wed Jul 2 2003
System image file is "slot0:c7200-js-mz.120-7.T.bin"
cisco 7204VXR (NPE300) processor with 122880K/40960K bytes of memory.
R7000 CPU at 262Mhz, Implementation 39, Rev 2.1, 256KB L2, 2048KB L3 C
4 slot VXR midplane, Version 2.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
3 Serial network interface(s)
8 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
Thank you very much !
Silver
the line
is telling you that this box crashed .
this is more than likely hardware . Open a Tac case ,
Thank you very much !!!!
173
