Router problem
I have 2621 router.
When I started this router, I get ASCII character
rather than login prompt.
I tried to change the baud rate for console access to fix this problem but would't work.
Can anyone let me know what is wrong with this device
giving me strange characters on startup.
Thanks/Regards
Amir
1 REPLY
Silver
Re: Router problem
Apparently, looks like bit rate problem. Try connecting at various possible speeds. Are you using the right cable?
Even if you are getting strange character, see if you can still type password (even if it is not asking for password), login to the router and run a command, say reload.
HTH.
93
