Router Problem?
I'm trying to log into Cisco 4500 thru telnet giving its ip address and port number.
But after I type the password in telnet it shows the message "Password OK" and after that nothing is working. Did you have such a problem before? Any suggestions would be appreciated.
/rustam
Re: Router Problem?
You shouldn't need to specify a port number if you're only telneting to the router.
What port number is it? If its 2065, that means you're doing a reverse telnet to your AUX port (I'm pretty sure its 2065 on a 4500). The OK may be an AT prompt.
Mick.
Re: Router Problem?
The thing is that we were connecting to the router through the Terminal server. But now I found out why it didn't work. The router was off. So I could telnet only Terminal Server and then nothing worked(of course).
Thank's for info.
119
