02-01-2012 08:45 AM - edited 03-03-2019 06:29 AM
My router is sitting idle and only does static routing - this router is used to reverse-telnet in the production lab.
CPU is nearly 99% most of the time according to the "Last 72 hours".
When I run sh process cpu, it always shows 0% to 5%.
Any ideas?
Frank
v6-Mgr# sh proc cpu hist
v6-Mgr 11:29:34 AM Wednesday Feb 1 2012 EST
2222222222 111112222244444
100
90
80
70
60
50
40
30
20
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
1 8 1 1 1 1 1
440344432352532322232214242233334333324633554533233442222243
100
90
80 *
70 *
60 *
50 *
40 *
30 *
20 * * *
10 * # * * * * * ** * *
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU
999698897998686669899989699645579999654499695889669798989999999736098899
999597799997724599990729899659419999583699092969359299969919999391094299
100 *** * * ** * * * * ** **** ** * * * * * ** **** ** **
90 *** **** *** ***** * ** **** ** * *** * *********** ** **
80 *** ******** * ******* ** **** ** * *** * *********** ******
70 ************** ************* ****** ** * *** *************** ******
60 **************************** * ******* **** ******************* *******
50 ************************************** ************************* *******
40 ************************************************************************
30 ************************************************************************
20 ************************************************************************
10 ************************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
* = maximum CPU% # = average CPU%
02-07-2012 10:15 PM
If you look at 60 mins graph, you would see spike reaching up to 80-85%, which is the reason you are seeing your 72 hrs graph on full.
I recommend that if you don't have ip cef enable, then go ahead and enable ip cef on all the interface which are in use.
HTH,
Smitesh
02-08-2012 12:57 PM
Just to add one more thing, since these spikes are super short in time (at least it looks like that)
Maybe the EEM script can help you to try and collect mode info of the processor usage at the time of the spike
https://supportforums.cisco.com/docs/DOC-17985
cheers
Dejan
