routers and hubs
Does anyone have any Ideas on how I can hook up a network system using the direcway satillite modems, which use a usb connection to hook into the main computer.
1 REPLY
Re: routers and hubs
The only way would be to use a PC (Windows, linux, etc) with a regular ethernet NIC and the USB satelite connection and either route between these interfaces and the router, or bridge between the 2 interfaces on the PC and route on the router interface.
97
