Routing 0r Switching Problem
hi all
i am in campus network.i am using 172.16.0.x 255.255.255.0 for proxy machine.There are 16 subnetwork(VLANS configured for every subnet) with mask /24. now problm starts when i give /16 mask to any machine of any vlan then it is able to brows or ping any device in the network even when i give a differnt gateway to the machine(for example i m giving gateway of vlan 8 to the machine of vlan 2).
and when i did trace route with /16 mask the packet got routed to zonal device and then back to core. and when use /24 i got core svi directly.
vlans are configured at core and zone.
Waitng for help
Singh
Hall of Fame Super Silver
Re: Routing 0r Switching Problem
Singh
I am not clear if you really have a problem. It sounds like things are working. But if you do not want things to work when the mask on the workstation is different from the mask on the router, then you should disable proxy arp.
With the workstation mask set at /16 it believes that any address in 172.16 is local and will arp for it rather than forwarding to its gateway. If proxy arp is enabled (and it is enabled by default) then the router will answer the arp and the packets will be forwarded. If you disable proxy arp then the router will not respond to arp when the destination is in a remote subnet. Perhaps this is the behavior that you want.
Rick
Silver
I think the zonal device is using proxy-arp. Check out the following link
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094adb.shtml
92
