routing between "same" networks
hi all,
we have two departmernt LANs we want to connect, but both are using the same network ip (e.g. 172.16.0.0) and changing the addresses on one site is not possible.
I heard that for this kind of scenario is a solution available with two NAT tables.
Can someone help me out and tell me how the needed technologie is called or how we can solve the problem?
Thanks a lot!
Best,
Christian
Bronze
Re: routing between "same" networks
Hi Christian
Check out the config guides. It explaines all the nat issues. If i understand
you problem correct you should be able to solve it with the part "translating
overlapping addresses".
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/ip_c/ipcprt1/1cdipadr.htm#1002518
Hope that gives you the idea.
Roger
Gold
Christian,
What you are describing sounds like "overlapping networks". Cisco IOS routers, VPN Concentrators, or PIX Firewalls can be used to connect overlapping networks. If you search Cisco's website for "overlapping networks" there are configuration examples for the above-mentioned equipment; which one you use depends on what equipment you have, and how it's connected.
From IP Addressing Services, NAT Frequently Asked Questions:
"IP address overlapping refers to the situation where two locations that want to inter-connect are both using the same IP address scheme. This is not an unusual occurrence, and will often happen when companies merge or are acquired. Without special support, the two locations will not be able to connect and establish sessions. The overlapped IP addresses can be public addresses assigned to other companies, private addresses assigned to other companies already, or from the range of private addresses as defined in RFC 1918 . Private IP addresses are un-routable and require NAT translations to allow for connections to the outside world.
The solution involves intercepting DNS name query responses from the outside to the inside, setting up a translation for the outside address, and fixing up the DNS response before forwarding it onto the inside host. A DNS server is required to be involved on both sides of the NAT device, to resolve users wanting to connect between both networks.
NAT is able to inspect and perform address translation on the contents of DNS A and PTR records.
For more information, refer to Using NAT in Overlapping Networks."
Here's the link to the above reference:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f30.shtml
Hope this helps.
hi roger and konigl,
now I am on the right track, thanks a lot!
Christian
153
