Routing between two ethernet int?
I hve a 4006SGM which acts much like a 2600 router. It has a GigabitEthernet0/0 and a Fastethernet0/0. On Gigabitethernet0/0 I have ip 192.168.0.1, on Fa0/0 I have 158.114.52.41. I would like to have hosts on the 192.168.0.x network access the 158.114.52.x network.
Any Ideas? I cannot seem to get the routing working. I would like to use static routes as nothing should change on this network route wise..
  • Other Network Infrastructure Subjects
Re: Routing between two ethernet int?
I don't know about the 4006SGM specifically but as soon as you put an IP address on an interface on a router then you enable IP processing. Putting IP addresses on 2 interfaces should enable IP routing between them.
There is no need for static routes or any routing protocol between directly connected networks.
Assuming that the hosts (on both 'sides' of the router) have the appropriate default gateway address configured (the IP address of the router interface on their LAN) and both interfaces are up, then the only other option left is that ip routing needs to be enabled. This, surprise, surprise, is done by entering 'ip routing' in global config.
if I get into the AGM I can ping hosts on each subnet, but on the 192.168.x.x network I cannot ping anything.
Here is some of my config:
interface FastEthernet0/0
description connected to TGN
ip address 158.114.52.41 255.255.254.0
ip nat outside
no ip mroute-cache
speed auto
full-duplex
interface GigabitEthernet0/0
description connected to VOIP
ip address 192.168.0.1 255.255.255.0
ip nat inside
no ip mroute-cache
no negotiation auto
ip default-gateway 158.114.52.1
ip classless
ip route 0.0.0.0 0.0.0.0 158.114.52.1
ip route 192.168.0.0 255.255.255.0 FastEthernet0/0
sh ip route:
Gateway of last resort is 158.114.52.1 to network 0.0.0.0
158.114.0.0/23 is subnetted, 1 subnets
C 158.114.52.0 is directly connected, FastEthernet0/0
C 127.0.0.0/8 is directly connected, Vlan0
C 192.168.0.0/24 is directly connected, GigabitEthernet0/0
S* 0.0.0.0/0 [1/0] via 158.114.52.1
Every one have the correct gateways and such.
Anonymous
N/A
This line looks like your problem to me:
You are, in effect, telling your router that the 192.168.0.0 network is out FE0/0, when in fact it's out the GE0/0 interface.
Kelly
I removed the line, but I still cannot ping. I debuged icmp and I get...
01:39:48: ICMP: dst (158.114.52.41) port unreachable sent to 192.168.0.15
Remove the ip default-gateway command.
208
