Routing Config Question
I have a 1605r router. I have set it up to exist on a small network. Cable modem to the router and the router goes to a switch. There are 6 machines on the network.
The ISP changed its DNS numbers and I changed those in my router config at the name-server and the dns-server lines respectively. I placed the router back on the network and everything is routing traffic fine to the outside.
One exception. I cannot route traffic back to my network at Branch A. Both network are independant and exist on their own cable modem. There are 2 web servers I need to get to there at Branch A. Does anyone see anything in the config below that is allowing me to pass traffic to everyplace except address's of 24.197.19.xxx? I can't even ping those addresses from the router. Just times out. I can ping everything else just fine. The address of the router is the same address as the ones I cannot ping... I was given several statics from my ISP all on the same network.
Why can I not see my own network at Branch A, but can see the rest of the world fine?
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname
logging rate-limit console 10 except errors
enable secret xxxxx
username xxxx password xxxxx
ip subnet-zero
no ip source-route
no ip finger
ip name-server 209.225.8.42
ip name-server x.x.x.x
ip dhcp pool DHCPPoolLAN_1
network 192.168.100.0 255.255.255.0
--More—
default-router 192.168.100.1
dns-server 209.225.x.x x.x.141.226
interface Ethernet0
ip address 24.197.x.x 255.255.252.0
no ip proxy-arp
ip nat outside
ip rip send version 1 2
ip rip receive version 1 2
no ip route-cache
interface Ethernet1
ip address 192.168.100.1 255.255.255.0
no ip proxy-arp
ip nat inside
no ip route-cache
router rip
--More—
no ip route-cache
router rip
network 24.0.0.0
ip nat inside source list 11 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 24.197.16.1
no ip http server
access-list 11 permit 192.168.100.0 0.0.0.255
line con 0
exec-timeout 0 0
transport input none
line vty 0 4
exec-timeout 0 0
login local
end
Bryan
  • Other Network Infrastructure Subjects
1 REPLY
Re: Routing Config Question
Bryan,
You may be having that issue because you are advertising that you own 24.0.0.0 in your rip statements. Are you receiving RIP from anywhere? Is your cable provider sending you RIP? If you are absolutely stuck on keeping RIP then take out the network 24.0.0.0 statement.
148
