Routing design
I have the following requirements.....
I work for a ferry company and we have a small office in all the ports we dock, with a small Cisco router in each. ie. I have network access to the remote offices.
Each ship has a small LAN (unix server etc).
We are wanting to implement a WLAN between the ships and the small office. So we can administer the Unix servers.
We have looked at configuring a DHCP server on the Cisco routers in the small office and a router on the ship with two LAN i/fs, with one using DHCP so that each time the ferry docks the router will recieve a IP address.
The question I have is this how do I handle routing (we currently run EIGRP).
Is there a way using EIGRP to tell it to put an interface (as opposed to a static IP address) into a routing process so that we can communicate with the ships LAN? Can I use something else.
I may have been a bit vague, but any ideas would be appreciated.
Re: Routing design
you can't enable an interface with EIGRP.
However, I guess you can predict the range used by DHCP.
So, enable eigrp with an address to will match the range.
ie:
router eigrp 1
network 10.0.0.0
Re: Routing design
I guess what I could do is allocate a clasfull class c address range for all the small offices located at each port.
Then subnet each small office so each has a unique network address, and then since when configuring a router to use EIGRP to specify the clasfull address, the address range would always be valid regardless of which port the ship is docked.
Sound sane to you?
86
