You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
ROUTING HELP
I have a network below a network as follows
ser 0 10.101.101.104 top net
ser 0 10.101.101.105 target net
eth 0 10.7.9.1
ip route 0.0.0.0 0.0.0.0 10.101.101.104
Because of an unsupoorted printer with an IP of 192.168.192.150 on the
lower network, i need routes for that ip network to stay in the network and not shoot up the gateway. each workstatiosn has a second ip added to each of its
primary interfaces (10.7.9.0) that are a corresponding 192.168.192.0
my top router has
ip route 192.168.192.0 255.255.255.0 10.101.101.105
so i think i am getting some bouncing
at the lower router i use ip route 192.168.192.0 255.255.255.0 10.7.9.1
and get bad hop, it is this router
any thoughts
  • Other Network Infrastructure Subjects
1 REPLY
Silver
Re: ROUTING HELP
You might try, instead of static routes, to put a secondary address for the 192.168.192.0 network on your ethernet0 (10.7.9.1). Doing this you'd also not need to put these secondary addresses on all your clients for them to access this printer (although if performance is a concern since they'd have to go in and back out of the router to get there) then keep it the way you've got it.
To add a secondary address, lets say 192.168.192.1, you'd do the following:
1. Go into config mode (config t)
2. Go into interface config (interface E0)
3. Assign another (secondary IP) ip address 192.168.192.1 255.255.255.0 secondary
**NOTE make sure you put the secondary or you'll wipe out the primary address.Hope this helps.
Don
79
