routing help
I have a 2610 with 2 ethernet interfaces and IOS 12.2(16). The ip addresses for those interfaces are 172.16.0.90/16 and 172.25.0.1/16.
I can ping all hosts on 172.16.0.0 subnet from the router using the 172.25.0.1 interface as source. But when I try to ping a host in 172.16.0.0/16 subnet from a host (172.25.5.1/16) it doesn't respond.
here is my router config :
IOSFW1#sh config
Using 904 out of 29688 bytes
version 12.2
service config
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname IOSFW1
logging queue-limit 100
enable secret xxxxxxx
enable password xxxxxx
ip subnet-zero
ip audit notify log
ip audit po max-events 100
call rsvp-sync
interface Ethernet0/0
bandwidth 100000
ip address 172.16.0.90 255.255.0.0
full-duplex
no mop enabled
interface Serial0/0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Ethernet1/0
bandwidth 100000
ip address 172.25.0.1 255.255.0.0
full-duplex
ip classless
ip route 172.17.0.0 255.255.0.0 172.16.0.5
ip route 172.18.0.0 255.255.0.0 172.16.0.5
ip route 172.19.0.0 255.255.0.0 172.16.0.5
ip http server
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password xxxxx
login
end
Thanks for youe help in advance
Re: routing help
Did you check whether you are able to ping the host (172.25.5.1/16) from the router. Also check if the host is set with the right default gateway (172.25.0.1/16.)
Re: routing help
Thanks for your help and my appologies.....typo on the gateway....typed in 172.25.1.0 instead of 172.25.0.1
Thanks again
Re: routing help
The typo error doesnt realy matter, but, you should check the default gateway setting son the hosts on 172.25.0.0/16 network. Also ping from the host to the router and see if you can reach it.
204
