Webcast-Catalyst9k
Routing Issue
I have a 2610 router with followingh config'
interface ethernet0/0
ip address 202.188.120.1 255.255.255.248
bri0/0
ip unnumbered ethernet0/0
dialer idle-timeout 900
ip classless
ip route 0.0.0.0 0.0.0.0 bri0/0 --> L1
ip route 0.0.0.0 0.0.0.0 161.142.189.5 -- L2
For L1 above, I experienced that this default route will make the bri0/0 always up the link will never down the link even with "dialer idle-timeout 900". How to solve this ?
L1 and L2 above, why L2 is still needed as L1 already routes every thing to bri0/0?
How to use bri0/0 routing to backup another router (DDR) in term of routing ?
Please help.
Thank you.
Silver
Re: Routing Issue
to have bri0/0 dial dynamic you need to add some parameters , this is a minimal config
interface dialer 1
ip address xxxxxx
dialer in-band
dialer -group 1 (this bonds dialer-list 1 to the interface )
dialer idle-timeout 60
global commands
you may want to add some items to access-list 101 to become more granular as to what is permitted to make a call
access-list 101 deny ip any host 255.255.255.255
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
Re: Routing Issue
Please explain what do the following two commands do ;
Please help...
T.Q.
Silver
Re: Routing Issue
the first line denies broadcast traffic from bringing up the line ,
the second line allows all other ip traffic to bring up the line.
dialer-list 1 uses access-list 101 to define what is allowed to make a call , it is the associated to an interface by using the dialer-group command
Re: Routing Issue
hi,
your ethernet interface IP seems to be a public IP given to you by the ISP. Even if you are routing thru bri0 , only your uplink is going thru bri0 whereas your downlionk is coming thru the L2. if your criteria is to use yr ISDN only when yr L2 is down, then DDR has to be configured. give a floating route to the BRI0 interface and use the BRI interface as the backup interface.
Ramesh
97
