Webcast-Catalyst9k
routing metrics
If my router has learned a router via eigrp, which has a AD of 90, if I setup a static route with AD of say 120, if the eigrp route goes down, will it use the static route ?
1 REPLY
Re: routing metrics
Hi Carl
It should be able to use this secondary route with higher AD once your primary goes down provided you dont get another one with lesser than 120 as AD.
regds
114
