Routing mutiple T1's between sites
For redundancy we have two separate T1 connections between
all our sites. I was wondering how to best utilize this bandwidth by
aggregating the bandwidth. We have different T1 providers(ATT& MCI).
Sites are Point to Point.
I did not want to use COS or priority queuing.
Is there a way to set up traffic to use the least loaded path ?
And how would the routing be set up ?
Thanks in advance
Re: Routing mutiple T1's between sites
You can use both the T1 in a bundle using "ppp multilink" (assuming you have ppp encapsulation). With the the packets will be load balanced between two links. Visit
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
Thank You.
The current encapsulations is frame-relay.
The environment is hub and spoke from 4 remote sites to
the corporate office. Will this still work ?
Will multilink take into account the loads on each T1 ?
The reason I am asking is our 4 remote sites have a primary T1
via MCI that comes into our Corporate site via inverse Mux using 4T1's.
The 4 new AT&T T1's at the remote sites will share a single T1 at
the corporate site. This config was for backup and redundancy. I had
Initially wanted to use HSRP, but thought to have them online would be a
better option. The remote routers are 3620's with a single e0, and two
serial connections to seperate DSU's to the seperate service providers T1's.
Would Multilink
You couldn't use PPP encapsulation on a Frame Relay circuit. Your other option is CEF or even routing protocol load balancing.
As long as those T1's are point-to-point, it will work. You can use ppp over frame relay for that.
Here is the link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t1/pppframe.htm
Another one
http://www.cisco.com/warp/public/788/voice-qos/designing-mlp-over-fr-atm.html
84
