Routing on a stick configuration
I was reading up CCNP switching guide and got this qns on configuring VLAN routing using external router and a switch.
Router A FA0/1 ---link--- Switch A FA0/1
Switch A has got a number of VLAN eg 10, 20, 30, 40
Router A has got subinterface according to VLAN number eg FA0/1.10=VLAN10, FA0/1.20=VLAN20 etc
1) The thing is i have got no idea how to configure Router A's subinterfaces to associate with the VLANs
2) The link shd be a trunk link right?
3) Switch A shd be a VTP Server or Transparent?
4) Router A shd be a VTP Server or Transparent?
how would u guys go abt configuration both devices so VLANs can route between each other...?
-Steven-
Re: Routing on a stick configuration
Router doesnt participate in VTP. VTP is only between switches.
Configure The link on the switch to router as a trunk.
On Switch -configure the following
int fa0/1 ---> trunk port on switch
switchport mode trunk
switchport trunk encapsulation dot1q (or isl)
switchport trunk native vlan 1
On Router - configure the following
int fa0/1.10
encapsulation dot1q 10 (can use isl also)
ip add
int fa0/1.20
encapsulation dot1q 20 (can use isl also)
ip add
That should do it.
The link below should have a sample configuration along with explantion. Hope it helps.
http://www.cisco.com/warp/public/473/50.shtml
94
