08-13-2006 03:08 PM - edited 03-03-2019 04:29 AM
if I have my core router, and a 3550 switch on my lan, I have then a wan link from this 3550 to my other office, how do I route to the layer 3 port on the switch, Do I point a route to vlan 1 on the switch from my core ?
08-13-2006 03:29 PM
If you are using static route, simply configure a static route on the core router that points to the IP address of the vlan interface on the 3550.
Hope that helps - pls do rate the post if it does.
Paresh
08-14-2006 02:20 PM
Hi Paresh
Is this the normal pratice then ? would you mainly use layer 3 ports on my switch for wan links ? then to route to this layer 3 port I would point a route to vlan 1 on the switch from my core ?
cheers
08-14-2006 02:32 PM
There are couple of ways you can configure the switch for WAN (routed) links.
On a layer 3 switch you can make the switchport a layer 3 (routed) port by issuing the command 'no switchport' on the physical interface and configuring all IP address & parameters on this interface. In this case, the route on your core device would point to this address as the next hop.
(or)
You can create a SVI (logical) VLAN interface and assign it the IP address. In this case, the uplink port connected to your core would be acting as a switchport (default). The route from the core would be pointing to the next hop address of the SVI (vlan) interface of this switch.
Hope that helps!
Sundar
08-15-2006 12:29 AM
Hi Sundar
thanks for the reply , in your first example, are you saying to route to this layer 3 port from my core I would assign it 2 ip addresses ? 1 for my local lan and the other for the wan link ?
08-16-2006 04:16 AM
Hi there, would We normally have these layer ports plugged straight into a router, or Can we plug them into another switch ?
