Routing Port
I am trying to make a 3550 Port a routing port, but when i make a routing port through "no switchport"
display message VLAN1 is already enabled for management so ip cannot be assigned to routing port.
thank you.
Re: Routing Port
Hi Mansoor,
Can you please post the output of that port.
sh run int
Ankur
Re: Routing Port
Can you make sure ip routing is enabled? Can you also do a show ip route and post it here at least if you do not want to post the show run and show ver?
Re: Routing Port
Hi Mansoor ,
AFAIK on 3550 switch you can only configure one port with an IP address .If you have already configured VLAN with one IP address you cant configure other IP address. To confirm what you can do this if you remove the IP address of VLAN 1 and then add IP address to that Routing Port or to someother VLAN.
Hope that helps..
regards
Ab
Re: Routing Port
Ab
[q]AFAIK on 3550 switch you can only configure one port with an IP address [/q]
that's not true, you can make 24/48 port router from a Cat3550 / 3560
this applies to 2950 - only 1 ip interface
Re: Routing Port
Hi Salomon,
I tried configuring 2 IPs on WS-C3548-XL-EN , but it was letting me configure.i dont know may be u r right.
regards
Ab
104
