Routing problem between two networks
Scenario:
Network A:
Computer A:192.168.1.1 255.255.255.0
Computer B:192.168.1.2 255.255.255.0
Computer C:192.168.1.3 255.255.255.0
Route A :192.168.1.9 255.255.255.0
network B :
Route B:192.168.27.1 255.255.255.0
Computer A:192.168.27.2 255.255.255.0 <-- First NIC
Computer A:192.168.7.1 255.255.255.0 <---second NIC
Computer B:192.168.7.2 255.255.255.0
Computer C:192.168.7.3 255.255.255.0
Router B attached to Fist NIC of server at network B and IP routing enabled at this server. These networks connected through leased line.
From any workstations of network A , can ping to Router A & Router B & first NIC of network B, and From network B can ping to Router A & Router B but no beyond them ( Routing enables on server ).
Here are two routers' configuration . How can set them to pass packets from network A to B and vice versa?
Router A
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname Router_A
interface Ethernet0
ip address 192.168.1.9 255.255.255.0
interface Serial0
ip unnumbered Ethernet0
encapsulation ppp
interface Serial1
no ip address
shutdown
shutdown
interface Serial2
no ip address
shutdown
interface Serial3
no ip address
shutdown
interface Serial4
no ip address
shutdown
interface Serial5
no ip address
shutdown
interface Serial6
no ip address
shutdown
interface Serial7
no ip address
no ip address
shutdown
interface Serial8
no ip address
shutdown
interface Serial9
no ip address
shutdown
interface BRI0
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.3
ip route 192.168.1.0 255.255.255.0 Ethernet0
ip route 192.168.7.0 255.255.255.0 192.168.27.1
ip route 192.168.27.0 255.255.255.0 Serial0
line con 0
line aux 0
line vty 0 4
login
end
Router B
version 11.2
hostname Router_B
interface Ethernet0
ip address 192.168.27.1 255.255.255.0
interface Serial0
encapsulation ppp
interface Serial1
no ip address
shutdown
shutdown
interface Serial2
no ip address
shutdown
interface Serial3
no ip address
shutdown
interface Serial4
no ip address
shutdown
interface Serial5
no ip address
shutdown
interface Serial6
no ip address
shutdown
interface Serial7
no ip address
no ip address
shutdown
interface Serial8
no ip address
shutdown
interface Serial9
no ip address
shutdown
interface BRI0
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 serial 0
ip route 192.168.1.0 255.255.255.0 192.168.1.9
ip route 192.168.7.0 255.255.255.0 192.168.27.2
ip route 192.168.27.0 255.255.255.0 ethernet 0
line con 0
line aux 0
line vty 0 4
login
end
Re: Routing problem between two networks
Perhaps you must add second NIC of computer A in network B (192.168.27.2) as next hop for network 192.168.7.0 in router A:
instead of :
ip route 192.168.7.0 255.255.255.0 192.168.27.1.
Hope that help.
First of all i would suggest you to clean up certain routes you have added in each router.
On router A
ip route 0.0.0.0 0.0.0.0 192.168.1.3 - instead of this make it point to serial 0. Your default route points to Computer-3
ip route 192.168.1.0 255.255.255.0 Ethernet0 - there is no need for this (directly connected)
ip route 192.168.7.0 255.255.255.0 192.168.27.1 - if you have a default route as in step 1, there is no need for this.
ip route 192.168.27.0 255.255.255.0 Serial0 - since you have default route as in step 1 there is no need for this.
So concluding the configs of router A, just one default route pointing to serial0 should work.
Or you can just add 2 statements..on router A.
ip route 192.168.7.0 255.255.255.0 serial 0
ip route 192.168.27.0 255.255.255.0 serial 0
Similarly on router B
ip route 0.0.0.0 0.0.0.0 serial 0 - this would work fine.
ip route 192.168.1.0 255.255.255.0 192.168.1.9 - - no need since there is default route
ip route 192.168.7.0 255.255.255.0 192.168.27.2 - needed.
ip route 192.168.27.0 255.255.255.0 ethernet 0 - no need, since its directly connected.
In summary,
ip route 192.168.7.0 255.255.255.0 192.168.7.2
These 2 should work fine.
Servers NIC 1 should point to 192.168.7.1 as default gateway.
Yes Shanky, that is.
Hi Shanky
It works fine.
117
