06-30-2003 10:11 PM - edited 03-02-2019 08:32 AM
I am sending the IOS which is up and running. Only problem is of routing, i think. The user can't connect to the internet through the router. When i ping any internet IP within the IOS is working fine.
The Lan has the IP range 192.168.1.5 - 192.168.1.45
The router Lan IP is 192.168.1.100
I was trying from the comp with IP 192.168.1.19. In this computer i put the gateway as router ethernet (192.168.1.100) but nothing pings outside the lan.
What would be the default gateway for the PCs in the Local LAN?
Once this configuration is done. We are connecting a PIX 506E. I think the BRI0, E0 of router & E0 of PIX would be the IPs in the same range i.e. 213.X.X.a, 213.x.x.b, 213.x.x.c and the E1(internal) of PIX will be on local lan network.
If any one can provide a basic PIX config so that the local lan can access the internet through the router & PIX.
Any suggestion will be appreciated
regards
shoeb
==========================IOS======================
Current configuration : 1054 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname cisco801
enable secret 5 $1$1li8$9.LARdla6pfbYPYYn5y2i0
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Ethernet0
ip address 192.168.1.100 255.255.255.0
ip nat inside
no cdp enable
interface BRI0
no ip address
ip nat outside
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp authentication pap callin
interface Dialer1
description CONNECTION TO INTERNET
ip address 213.x.x.x 255.255.255.248
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string 4004444
dialer persistent
dialer-group 1
no cdp enable
ppp pap sent-username xxxxx password 0 xxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
dialer-list 1 protocol ip permit
no cdp run
banner login ^C RESTRICTED ACCESS ^C
line con 0
password xxx
login
stopbits 1
line vty 0 4
password xxx
login
no rcapi server
end
Solved! Go to Solution.
07-01-2003 01:34 AM
Morning Shoeb - It's Jay !!
I've sent you info. on your e-mail account (yahoo). Pls. read and check and let me know how you get on.
Hope this helps and good luck --
06-30-2003 10:44 PM
The Gateway for the PC you best set to the LAN IP of the router (192.168.1.100).
I can see in you config that you have on the ethernet the "ip nat insider" command. There is still some commands missing to get nat work proberly.
First you have to deside which is your outside.... in this case it would be the dialer interface.
And second you have to define what to nat. Here a link to the nat konfig guide:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipr_c/ipcprt1/1cfipadr.htm
Here you can find all about nat.
Try to complete that and then we can see further.
Roger
07-01-2003 01:34 AM
