Community Member
Routing problem with 2501
I'm having routing problems. I am trying to route from my WAN segments to 161.125.3.100 and 161.125.198.5 which is on one segment of my WAN. Each segment has a 2501 with the static route pointing to the main 2501(the config will follow) i can ping 161.125.3.100 and 161.125.198.5 from the main 2501. When i try to traceroute from the other segments it is stopping at the main 2501.
Configuation file:
SW2501#show run
Building configuration...
Current configuration:
version 11.3
service udp-small-servers
service tcp-small-servers
hostname SW2501
enable secret 5 --moderator edit--
enable password
ip subnet-zero
ip nat pool lawrnc 172.21.25.17 172.21.25.46 prefix-length 14
ip nat pool newc 172.21.25.81 172.21.25.94 prefix-length 14
ip nat pool butler 172.21.25.1 172.21.25.14 prefix-length 14
ip nat pool washng 172.21.25.49 172.21.25.62 prefix-length 14
ip nat pool westmr 172.21.25.65 172.21.25.78 prefix-length 14
ip nat pool brooml 172.21.25.97 172.21.25.110 prefix-length 14
ip nat pool ftp 172.21.25.127 172.21.25.127 prefix-length 14
ip nat pool newcdial 172.21.25.95 172.21.25.96 prefix-length 14
ip nat pool westmail 172.21.25.46 172.21.25.46 prefix-length 14
ip nat inside source list 10 pool butler
ip nat inside source list 20 pool butler
ip nat inside source list 32 pool lawrnc
ip nat inside source list 33 pool lawrnc
ip nat inside source list 34 pool lawrnc
ip nat inside source list 35 pool lawrnc
ip nat inside source list 36 pool lawrnc
ip nat inside source list 50 pool ftp
ip nat inside source list 51 pool westmail
ip nat inside source list 63 pool lawrnc
ip nat inside source list 65 pool westmr
ip nat inside source list 96 pool newcdial
ip nat inside source list 98 pool brooml
ip nat inside source list 99 pool newc
ip nat inside source static 176.16.0.5 172.21.25.127
ip host BR 193.0.0.102
ip host FC 161.125.2.130
ip host WS 128.1.0.227
ip host LA 10.2.2.1
ip host WM 192.168.255.1
ip host utec 164.156.51.231
ip host Indy 192.168.222.1
ip name-server 206.101.113.2
interface Ethernet0
ip address 176.16.0.254 255.255.0.0
ip nat inside
no ip route-cache
no ip mroute-cache
interface Serial0
no ip address
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
bandwidth 768
no fair-queue
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
description To Broomall, PA dlci 32
ip address 180.23.14.1 255.255.255.252
ip nat inside
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 38
interface Serial0.2 point-to-point
description To Butler Co., PA dlci 32
ip address 189.23.14.2 255.255.255.252
ip nat inside
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 37
interface Serial0.3 point-to-point
description To Falls Church, VA dlci 30
ip address 161.125.2.129 255.255.255.252
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 34
interface Serial0.5 point-to-point
description To Lawrence Co., PA dlci 37
ip address 183.23.14.2 255.255.255.252
ip nat inside
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 33
interface Serial0.6 point-to-point
description To Washington Co., PA dlci 30
ip address 184.23.14.2 255.255.255.252
ip nat inside
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 36
interface Serial0.7 point-to-point
description To Westmoreland Co., PA dlci 30
ip address 187.23.14.2 255.255.255.252
ip nat inside
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 32
interface Serial0.8 point-to-point
description To Arm/Ind Co. dlci 30
ip address 187.23.14.5 255.255.255.252
ip nat inside
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 40
interface Serial1
ip address 172.17.152.26 255.255.255.128
ip nat outside
encapsulation frame-relay IETF
no ip route-cache
no ip mroute-cache
router rip
redistribute connected
network 176.16.0.0
network 180.23.0.0
network 183.23.0.0
network 184.23.0.0
network 187.23.0.0
network 189.23.0.0
distribute-list 11 in
ip classless
ip route 10.1.2.0 255.255.255.0 Serial0.5
ip route 10.2.2.0 255.255.255.0 Serial0.5
ip route 10.2.3.0 255.255.255.0 Serial0.5
ip route 10.9.2.0 255.255.255.0 187.23.14.1
ip route 10.250.69.0 255.255.255.0 Serial0.8
ip route 128.1.0.0 255.255.0.0 184.23.14.1
ip route 128.1.5.0 255.255.255.0 184.23.14.1
ip route 161.125.0.0 255.255.0.0 161.125.2.130
ip route 161.125.3.100 255.255.255.255 161.125.2.130
ip route 161.125.198.5 255.255.255.255 161.125.2.130
ip route 164.156.7.97 255.255.255.255 176.16.0.5
ip route 164.156.51.231 255.255.255.255 172.17.152.1
ip route 164.156.51.232 255.255.255.255 172.17.152.1
ip route 164.156.51.233 255.255.255.255 172.17.152.1
ip route 164.156.51.234 255.255.255.255 172.17.152.1
ip route 192.168.0.0 255.255.255.0 Serial0.8
ip route 192.168.1.211 255.255.255.255 192.168.255.1
ip route 192.168.50.0 255.255.255.0 187.23.14.1
ip route 192.168.222.0 255.255.255.0 Serial0.8
ip route 199.79.0.0 255.255.0.0 172.17.152.1
ip route 199.234.86.0 255.255.255.0 172.17.152.1
ip route 199.234.87.0 255.255.255.0 172.17.152.1
map-class frame-relay word
access-list 10 permit 192.168.82.0 0.0.0.255
access-list 11 deny 208.0.54.0 0.0.0.255
access-list 11 permit any
access-list 32 permit 10.2.2.0 0.0.0.255
access-list 33 permit 192.168.1.0 0.0.0.255
access-list 34 permit 10.9.2.0 0.0.0.255
access-list 35 permit 192.168.0.0 0.0.0.255
access-list 36 permit 192.168.50.0 0.0.0.255
access-list 50 permit 176.16.0.5
access-list 51 permit 192.168.255.250
access-list 63 permit 128.1.0.0 0.0.255.255
access-list 65 permit any
access-list 95 permit any
access-list 96 permit 176.16.1.0 0.0.0.255
access-list 98 permit 193.0.0.0 0.0.0.255
access-list 99 permit 176.16.0.0 0.0.0.255
snmp-server community public
snmp-server enable traps isdn call-information
snmp-server host 176.16.0.215
Community Member
Re: Routing problem with 2501
You didn't give us your configuration on the other routers, so I can't give you all the details that you may need to fix it, but I can tell you about some problems that I see.
Your software is pretty old. It may be bug free and functioning for your needs, but it may be worthwhile updating. That will not fix your problem, but consider it for a future project.
You are using a combination of RIP and static routes. There are better routing protocols available than RIP. RIP is a classful routing protocol, which limits the use of dis-contiguous subnets and variable length subnet masks. Yet, when I look at your config, I see that int s0.3 is using 161.125.2.129/32 and you say that 161.125.3.100 and 161.125.198.5 exist "on one segment of my WAN". You don't tell me the masks on those subnets but the /32 only allows two hosts - one at each end of the frame relay link. RIP will have trouble with this. Also, you are not redistributing the static routes into RIP, so the other locations are not learning of them.
I would suggest a complete change of plans. I would update the software to something more recent. I don't know your topology, so I don't know if static routes are the best choice, but given the number of locations, I would use a routing protocol and let it do it's job. I would enable OSPF, EIGRP or RIPv2. My personal choice in an all Cisco network would be EIGRP. In a mixed network I would use OSPF. I would then use private addressing on all WAN ports with a /32 mask. I would enable routing on all subnets and disable auto summary. Then I would sit back and watch it all work.
Community Member
First, I would like thank you for your expert input on the problems I am having. I work for a Non-profit and this is a legacy WAN. So, any input you may have will be greatly appreciated.
Let me try to explain the WAN to you. The reason for the NAT is that the Serial1 connection only allows a certain range of ip address to access their location.
Each of the different locations have their own private LANs.
A question I have is if I change the protocol on the main 2501 will I have to change the protocols on all the other 2501s?
The configuration that follows is from one of the other 2501 and the others have the same configuration except for ip addresses.
WestMoreland#show run
version 11.3
hostname WestMoreland
boot system flash 1:80240503.bin
enable secret
enable password LINE
interface Ethernet0
ip address 192.168.255.1 255.255.255.0
bandwidth 10000
interface Serial0
no ip address
no fair-queue
description TO BROOMALL
ip address 186.23.14.1 255.255.255.252
description TO NEW CASTLE
ip address 187.23.14.1 255.255.255.252
frame-relay interface-dlci 30
interface Serial1
no ip address
shutdown
router rip
network 186.23.0.0
network 187.23.0.0
network 192.168.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 187.23.14.2
ip route 10.9.2.0 255.255.255.0 192.168.255.250
ip route 161.125.0.0 255.255.0.0 161.125.2.129
ip route 192.168.1.0 255.255.255.0 192.168.255.250
ip route 192.168.1.211 255.255.255.255 10.9.2.71
ip route 192.168.50.0 255.255.255.0 192.168.255.250
ip route 199.79.10.100 255.255.255.255 176.16.0.254
no logging console
line con 0
exec-timeout 0 0
password
line aux 0
password
transport input all
line vty 0 4
password
login
end
Community Member
In a hub and spoke network there are two different ways to attack the routing. Either one will work. If the spokes only need to talk to the host, I would put a static route in each of the remotes that points to the host, and a static route in the host for each spoke. It is simple and doesn't use any bandwidth. Also, you don't have to concern yourself with things like access lists to keep traffic where it belongs.
If the spokes need to talk to eachother, and you want to use static routes, you can use a default route at each spoke site that points to the hub, and a static route for each spoke at the hub. There will be one static route at the host fro each spoke so it depends on how much control and ongoing support you want.
If you decide to make it work and not have to maintain it, use a routing protocol. See my first response for that solution. And, to answer your question: Yes - your routing protocol must be the same at all locations unless you want to get into redistribution and other ugly stuff.
I would suggest that you take some time to look at the network as it is today, consider what you want it to do, then implement a long term solution.
254
