08-27-2003 06:39 PM - edited 03-02-2019 09:56 AM
I have two routers connected via frame-relay(point-to-point).
router 1
s0/0.1 - 1.1.1.1
s0/0.2 - 2.2.2.2
f0/0 - 3.3.3.3
router 2
s0/0.1 - 1.1.1.2
s0/0.2 - 20.20.20.20
f0/0 - 30.30.30.30
from router1 I can ping all the interfaces of the router2.
There are two networks behind router2 5.5.5.5 and 6.6.6.6, from router2 I can ping both the networks but when I try to traceroute from router1 on any of the networks it only reaches till 1.1.1.2 (router2 serial interface) and cannot find both the network. I can't ping them as well.
I checked the routing and everything is ok. I am using OSPF as routing protocol and in router1 I can see that it has discovered the correct path for the network.
Can anyone please help me that why I can't ping the network behind the router. I can ping all both the networks from router2 but not from router1.
thanks
Solved! Go to Solution.
08-27-2003 11:07 PM
Do 5.5.5.5 and 6.6.6.6 know how to get back to router 1 (1.1.1.1)? It could very well be that your pings are making it to the destination networks but get lost coming back.
Kevin
08-28-2003 02:10 AM
On router1, do an extended ping, sourcing the ping from one of the serial interfaces, instead of the default source:
2651A#ping
Protocol [ip]:
Target IP address: 5.5.5.5
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: serial0/0
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 5.5.5.5, timeout is 2 seconds:
If this fails, then 5.5.5.5 doesn't know how to get off segments, which implies its default gateway is wrong, or, if it's a router, that it isn't hearing about the routes attached to router 1. If it's a router, are you running ospf with that router as well? Can you do a show ip ospf nei, and see if the adjacency is up?
If not, then we need to troubleshoot that. Generally, a debug ip ospf neighbor will tell us what's wrong there.
Russ.W
08-27-2003 11:07 PM
Kevin
08-28-2003 03:30 PM
Hi Kevin
I have checked and the routes are there because I can ping 3.3.3.3 from both the networks.
thanks
08-28-2003 02:10 AM
2651A#ping
Protocol [ip]:
Repeat count [5]:
Russ.W
08-28-2003 03:28 PM
Hi Russ,
I have checked the routes and its ok because I can ping 3.3.3.3 from 5.5.5.5 and 6.6.6.6 without any problem but I can't ping both the networks from 3.3.3.3
I can ping both the networks from router2 but not from router1.
And when I traceroute from router1 I can see the next hop i.e. router2 and thats it.
And currently I am not using any access-list to block any traffic.
Is there any debugging or anything else I can do?
I have added the static routes
thanks
08-28-2003 04:01 PM
Hi Russ,
I tried the extended ping from interface 3.3.3.3 and it works but if I try normal ping its not working.
Nitin
08-28-2003 04:50 PM
Hi Guys,
Thanks for the help, I fold out it was routing problem. As I only added the routes for 3.3.3.3 and not for 1.1.1.1, So when I was doing normal ping it was going out via 1.1.1.1 and in 5.5.5.5 it doesn't know how to reach 1.1.1.1 but when I was doing extended ping and use 3.3.3.3 it always worked because there were routes for this interface.
thanks for the help
