Webcast-Catalyst9k
routing problem
My lead IP(A.A.A.125) given to Serial Port is the IP ADDRESS LOGGED
on other side of the conection which are made by my server with ip
address (B.B.B.226,B.B.B.227,B.B.B.228,B.B.B.229.............................)
I tried a connection through a machine which had un-natted ip address (B.B.B.237). Even
in this case the ip address on the other side was A.A.A.125
I want same ip, i.e B.B.B.237 to be reflected @ the other side of the connection for un-nated ip's.
check my configuration below
regds
RamP
interface Ethernet0
ip address 192.168.1.1 255.255.255.0 secondary
ip address B.B.B.225 255.255.255.224
ip access-group 102 in
ip access-group 101 out
no ip directed-broadcast
ip nat inside
interface Serial0
backup delay 1 60
backup interface BRI0
ip address A.A.A.125 255.255.255.252
ip access-group 101 in
ip access-group 102 out
ip nat outside
custom-queue-list 1
interface BRI0
ip address negotiated
ip nat outside
encapsulation ppp
dialer idle-timeout 300
dialer string 28529200
dialer hold-queue 10
dialer-group 1
isdn switch-type basic-net3
ppp authentication pap callin
ppp pap sent-username xxxxx.in password xxxxx
ip nat inside source route-map rtm-nat-bri0 interface BRI0 overload
ip nat inside source route-map rtm-nat-ser0 interface Serial0 overload
ip nat inside source static 192.168.201.12 B.B.B.236
ip nat inside source static 192.168.201.11 B.B.B.235
ip nat inside source static 192.168.201.10 B.B.B.234
ip nat inside source static B.B.B.226 A.A.A.125
ip nat inside source static 192.168.201.3 B.B.B.227
ip nat inside source static 192.168.201.4 B.B.B.228
ip nat inside source static 192.168.201.5 B.B.B.229
ip nat inside source static 192.168.201.6 B.B.B.230
ip nat inside source static 192.168.201.7 B.B.B.231
ip nat inside source static 192.168.201.8 B.B.B.232
ip nat inside source static 192.168.201.9 B.B.B.233
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 BRI0 100
ip route 192.168.201.0 255.255.255.0 192.168.1.5
route-map rtm-nat-ser0 permit 10
match interface Serial0
route-map rtm-nat-bri0 permit 10
match interface BRI0
Re: routing problem
Hi.
I think you can solve your problem , using access-lists and joint them to your route-map
access-list 101 permit ip any any
access-list 102 permit ip any 217.0.0.0 0.255.255.255
dialer-list 1 protocol ip list 101
dialer-list 2 protocol ip list 102
route-map INTERNET permit 10
match ip address 102
match interface Dialer2
route-map Central-office permit 10
match ip address 101
match interface Dialer1
Only ip's matched against an access-list will be natted,
I hope it helps you
Manel
mvr
Re: routing problem
Hi !!
If you only want to NAT the staically defined addresses, then you should just remove the 2 dynamic NAT statements using route-maps.
The reason you see the example IP as .125 is that it matches on the route-map and gets PAT'ed to the interface address.
Mikael
95
