Routing Problem
I have got a LINUX PC with 2 NIC, NIC-1 eth0 192.168.1.1/24 & NIC-2 eth1 172.16.1.1/16,
2 Clients PC's, PC-1 10.2.1.1/24 & PC-2 10.2.9.1/24, configured VLAN on 3750, no gateway is set for the LINUX, default route is "route add -net 0.0.0.0 netmask 0.0.0.0 gw 0.0.0.0".
now from PC-1 & PC-2 i can able to reach the LINUX's both NIC's, when eth1 link goes down, i can able to reach eth0, but when eth0 goes down, i can't able to reach eth1, any thing else to be done on the switch side? i also tried, diff. route add commands in linux...
"route add -net 10.2.1.0 netmask 25.255.255.0 gw 192.168.1.252"
"route add -net 10.2.9.0 netmask 25.255.255.0 gw 192.168.1.252"
"route add -net 10.2.9.0 netmask 25.255.255.0 gw 172.16.1.252"
"route add -net 10.2.1.0 netmask 25.255.255.0 gw 172.16.1.252"
what ever commands i put at last,that is acting as a primary interface, which means when that primary interface goes down, the other interface will also go down, so how do i over come with this?
Note: i also tried putting the same subnet IP in eth0 & eth1, nothing worked out.
Cisco 3750 configuration
ip routing
interface vlan 2
ip address 192.168.1.252 255.255.255.0
interface vlan 3
ip address 172.16.1.252 255.255.0.0
interface vlan 4
ip address 10.2.1.252 255.255.255.0
interface vlan 5
ip address 10.2.9.252 255.255.255.0
router eigrp 1
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
Re: Routing Problem
Few things i would suggest to check out here.
1.Current routes configured in ur linux box,pls recheck the routes and remove the unwanted route statements from the boz.
2.Also can you post the full running config of your switch ?
3.Also whats the ip address/mask/default gateway configuration in your pcs ? can you recheck them once ..
regds
Re: Routing Problem
i just installed the linux & no routes are configured in that.
2 Clients are able to ping the linux 2 NIC by default.
IP address of 2 Client PC are
10.2.1.2/24 gw 10.2.1.252
10.2.9.2/24 gw 10.2.9.252
Cisco 3750 config.
3750#sh run
Building configuration...
Current configuration : 10897 bytes
! NVRAM config last updated at 07:20:56 UTC Thu Feb 9 2006 by anand
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname 3750
enable password 7 011113256500E12
username user privilege 5 password 7 00110003160A5955
no aaa new-model
switch 1 provision ws-c3750g-24t
ip subnet-zero
ip domain-name ueltv.org
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport access vlan 2
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/0/2
switchport access vlan 3
interface GigabitEthernet1/0/3
switchport access vlan 4
interface GigabitEthernet1/0/4
switchport access vlan 5
interface Vlan2
no ip route-cache
no ip mroute-cache
interface Vlan3
no ip route-cache
no ip mroute-cache
interface Vlan4
no ip route-cache
no ip mroute-cache
interface Vlan5
no ip route-cache
no ip mroute-cache
router eigrp 1
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
ip classless
ip http server
ip http authentication local
ip http secure-server
control-plane
Re: Routing Problem
hi
In your linux box instead of having 2 sets of routes thru the NICS with equal metric can you add/mention up some metric for the second set thru which is pointed via the secondary interface ?
Also once you make the link down can you try tracing from both the ends (from your pc as well as from your linux box) so that you can find out where the trace is getting stucked up..
regds
Re: Routing Problem
HI,
metric supports in windows, even in linux the commands accepts, but doesn't work out in linux, where as in windows it perfects work out, any how i hav solved this issue using routing policy in linux.thanks
229
